- Mute
- Permalink
- Report
hi, i want to use a bigger mill(for time saving) for the inner square and then finish the borders of the square with the 3mm mill.
- Mute
- Permalink
- Report
Okay, so what's your question?
If you have an accurate means of locating the part between Setups, this should be no issue. Where are you getting "hung up" on?
Seth Madore
- Mute
- Permalink
- Report
i want to know how to do a second process with a smaller mill only for the corners radius.
- Mute
- Permalink
- Report
OH! I took the "bigger mill" to mean an actually bigger machine. It was a case of terminology, you mean to say "bigger endmill"
Turn on Rest Machining, define the size of the prior tool:
Seth Madore
- Mute
- Permalink
- Report
ohh ok thank you for the correction, i do the rest machining but its throwing me a warning. i attach the file for you to see it.
- Mute
- Permalink
- Report
You are now using a 6mm endmill, but you have Rest Machining turned on, with 6mm defined. What you need is:
1: Pocket toolpath, 6mm endmill
2) Pocket toolpath, 3.175mm (.125) endmill, Rest Machining turned on, 6mm endmill defined as the "Tool Diameter"
Seth Madore
- Mute
- Permalink
- Report
ohh ok i got it, now it works but it look different than yours, and throw me an error. if you send me the one you do i can see whats wrong.
- Mute
- Permalink
- Report
Try this
Seth Madore
- Mute
- Permalink
- Report
i cant open the file it says that the version you save it its newer. and my fusion version its the lastest.
But thank you so much. you help me a lot!!
Fusion
