- Mute
- Permalink
- Report
When I send gcode to machine the z axis goes up to limit switch and stops
Newbie
I had this problem yesterday.
I entered a machine profile and the problem went away....I changed other things
The problem is back today after fusion 360 crashed and continued to crash reloading my file.
I am not sure what clears this problem and am unable to find what cleared it yesterday ...
- Mute
- Permalink
- Report
You probably have G28 or G53 at the start of your code/operation. Your post processor probably has an option to us either of those or to use [Clearance Plane]. Try using that instead.
- Mute
- Permalink
- Report
Yes on the fourth line from the top have a g28 g91 z0
I have know idea how to select clearance plane in the post processor.
Can you help me make the change?
- Mute
- Permalink
- Report
Found it
select nc program7
edit settings
safe retracts and home positioning
safe retracts Clearance height
Will try
- Mute
- Permalink
- Report
AAAh seems to be working
Where would I set this up so that it is always set to clearance height rather than editing nc program set ups every time
- Mute
- Permalink
- Report
As far as I recall, Fusion retains the settings of the post processor last selected. However, one could also edit the post processor to default to your preferred settings.
Seth Madore
Fusion
