morten4MDUW
242 Views, 3 Replies
is it possible to make 2D Pocket with side of tool, (5 axis)
Is it possible to make 2D Pocket toolpath with side of tool (tool D:150mm), when spindle is parallel with stock ?
seth.madore
in reply to: morten4MDUW
Do you have a sample file or image you could share so we have some better idea of what you're looking for?
Seth Madore
morten4MDUW
I have pocket and i want to remove material with tool side.
I have done this with trace toolpath and multiple depths, but tool is moving to much(yellow lines)
Is it possible to do it with 2d pocket toolpath and without so many yellow lines?
https://a360.co/3OAeyE0
seth.madore
2D Contour and Multiple Depths is what I think you want. If you get stuck on that, could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply
Seth Madore
