cadTPLWJ
6791 Views, 3 Replies
Error: Internal CAM kernel error. Please report through your support channel.
I got this message all of a sudden in the CAM section of a simple design. (Attached)
This particular Adaptive Clearing has worked and I have made a physical part from it.
Don´t know if the CAM setup is included in the .f3d file.
I was trying to make a finish pass for the top surface when this happened.
I do not know if anyone is interested in this but I followed the instruction "Please report through your support channel."
HughesTooling
in reply to: cadTPLWJ
One problem is you have the stock set to from solid but you do not have anything selected, for from solid you need to draw the stock as a body. After I set the stock to relative size box and setting the geometry tab like this and it works.
Mark
Mark Hughes
Owner, Hughes Tooling
cadTPLWJ
in reply to: HughesTooling
I had previously selected a solid body as stock. For some reason this was removed. I can very well have accidentaly removed it myself.
The error message however did not point in the problem direction.
You pointed out the problem correctly.
HughesTooling
I have had a body unselected on occasions when I've gone to the model work space and edited the body so that could be a reason for it unselecting.
Mark
Mark Hughes
