HughesTooling
in reply to: jgaertner
That line is just a comment not read by the control and the minus is just between the different info on the line, it actually show the minimum Z is +0.6546
Here's the first few lines from your file.
(* Tormach PathPilot Mill Post Processsor      r20160408 *)
(BSA-SIGN-SWALLOW-ENGRAVING-SAMPLE-5)
(T1  D=0.487 CR=0. TAPER=45DEG - ZMIN=0.6546 - CHAMFER MILL)
N10 G90 G54 G64 G50 G17 G40 G80 G94 G91.1 G49
N20 G20 (Inch)
N30 G30
(ENGRAVE3)
N50 G30
N60 T1 G43 H1 M6
N70 S5000 M3 M9
N80 G54
N90 G0 X1.7427 Y1.4954
N100 G0 Z1.2546
N110 G0 Z0.8546
N120 G1 Z0.6546 F39.4
N130 G1 X1.7209 Y1.4883 F23.4
N140 G1 X1.699 Y1.4815
N150 G1 X1.6769 Y1.4751
If you look a line N120 you can see the Z is 0.6546, if the top of your job is zero then this is not going to cut. I guess you have the origin in the setup wrong or different to the setup on the machine. Your best bet is to export the f3d file and attach so someone can help.
Mark
Mark Hughes
Owner, Hughes Tooling
