05-20-2016
09:38 AM
- Mute
- Permalink
- Report
05-20-2016
09:38 AM
Hello Form,
I am new to Fushion and learning G code.I am trying to create an engraved feature with a 45 degree engraving tool in a practice piece of MDF. I have created my G-code but on line 6 I get:
(T1 D=0.487 CR=0. TAPER=45DEG - ZMIN=0.6546 - CHAMFER MILL)
If I try to run the code on my CNC machine after zeroing my tool height on the work piece the code is executed above the work piece? I suspect it has something to do with this - ZMIN?
It is still unclear to me how to set the depth of cut I want in Fusion 360? I have read the Paramters section of the on line manual but this aspect does not make sense to me.
Any help would be appreciated. Code is attached.
Fusion
