04-07-2022
06:29 AM
- Mute
- Permalink
- Report
04-07-2022
06:29 AM
By using the Blend you get the tool using the curve of the Radius instead of just the Tip of the tool all the time, usually results in a smoother finish.
The Blend does it by default but if you are using for example the Parallel for the finish then you can set the toolpath to use the Tip or not option, see image below for how it works ![]()
Hope that helps ![]()
Fusion
