CHAY.HOBSON
in reply to: engineguy
@engineguy OK, so I've figured it out! I ran your toolpaths again straight out of the model you sent and this time it machined mid air! For some reason my post processor auto checks this box "rotate A-axis the opposite direction" When I uncheck this box all the toolpaths work!!
If you look at the difference in these 2 toolpaths it looks as if the tool on the blend doesn't get to the the top edges but it is just using the side of the tool.
The Flow toolpath maintains machining using the end of the tool.
Thank you so much for all your help! It is very much appreciated.
