04-07-2022
04:43 AM
- Mute
- Permalink
- Report
04-07-2022
04:43 AM
You don`t need the Flow to machine out that area, in fact for what you are doing you don`t need the Machining Extension at all, you are just doing 3+1 machining.
I used the Blend as the finishing Toolpath and it works fine, if you want it to go from side to side in the same direction as the Flow then change the "Drive Curve" selection from the two side edges to the two end arcs, what you will get then is just movement in the Z and Y axes, it should do the job OK.
I am not able to check any of your Flow settings as I don`t have that Extension which is why I tend to use the 3D options available
Fusion
