carlgren.martin
406 Views, 5 Replies
Simulation does not show cut in my stock
Hi, toolpaths and everything seems to work correct and I've used an imorted body from Solidworks as my stock. Actually all bodies used are imported SW models. However, when running simulation the cuts are not shown in the stock, no material is removed... This usually works when using a "fixed size box" or "relative size box" stock.
