engineguy
in reply to: CHAY.HOBSON
@CHAY.HOBSON
OK, few things to look at, the part/stock must be physically set up the same in Fusion and the machine. If the center of the part/stock that is aligned with the rotating center of the 4th axis as in my image then that is how it needs to be fixed in the machine.
Are you using the HAAS DWO and TCP ?
Which Post Processor ar you using Pre NGC or NGC
Which Axis is the 4th axis mounted along on the Machine ? X axis or Y axis ?
Can you upload a copy of the Post Processor that you are using ?
