04-04-2022
08:03 AM
- Mute
- Permalink
- Report
04-04-2022
08:03 AM
Have you tried working with tool orientation? With a rotary and tool orientation turned on you should be able to do some 3+1 milling and add some more rough passes to the part. Then finish with a single rotary, I did notice that this does add some time to the operations, but if you can use a larger tool or customize the settings a bit like change from helix to plunge you should be able to cut the time a bit. I've included my file, it's not done but it should give you an idea of what I've done. You are very much on the right track, I think this approach will get you to a much better spot than multiple rotary passes.
Joshua Aigen
Workshop Supervisor
Fusion
