- Mute
- Permalink
- Report
@engineguy The reason I don't like the NC Program method is everything I do is a one off so I just reuse files on my USB drives. I have machines setup I use in my setups so all setting and where I want to save to are set, I hit Post then select the file I want to save over on the USB stick. Using the NC Programs I have to type in a name each time, if all goes well I'll never post the same NC Program again.
Now I do see advantages as sometimes I post from one setup to 2 different machines so the extra effort of using NC Programs could be helpful as I could have 2 NC Programs using different posts. Problem is I might end up with 25 setups and 50 NC programs. I've asked for folders under the Setup folder for years but I guess not enough people end up with lots of setups to see the benefit.
Not saving the NC programs seem like the worst of both worlds!
Mark
Mark Hughes
Owner, Hughes Tooling
Fusion
