engineguy
in reply to: etfrench
@etfrench
@to3dornottobe
@kevinastrom
Hmmm, I am a little puzzled by these posts, I do not seem to be having the same issues, that is assuming I am understanding the problems. I probably have it wrong but anyway to proceed :slightly_smiling_face:
Let me see if I have got it right, what is being said is that when a File is either created or re-opened that the Destination Folder is blank and has to be re-entered ??
If that is the issue then I don`t get that here, if I re-open a file to modify something and using the NC Program system then all the boxes are still populated exactly as when it was saved, correct Post Processor, correct Program Name/Number, correct File Name and correct Destination Folder, nothing changes :slightly_smiling_face:
If I need to send the modified file to a different Destination then yes, of course that is a change but as long as you know the Destination folder then it is simply a matter of using the "Select Output Folder" option and navigating to the desired folder and saving the file there. When the file is opened again the Destination folder will be the last one selected so should be OK :slightly_smiling_face:
If there is any interest I can do a short Screencast showing what I have here :slightly_smiling_face:
