I don't think you will ever get anything machined to exactly replicate that design, even if you have a 5 axis machine. In between the petals, you will have some sort of fillet between the petals, whether you use a ball or flat end mill. If you redesigned it with fillets between the petals with the max fillet radius you can live with, without losing the detail that you want, that would represent what you will get as an end result, but realize, the smaller the fillet, the longer it will take, because that will limit your ball end mill choice.
I tried manipulating the solid model to add fillets but my CAD skills in Fusion are not up to the job.
LeoC
