Okay, so your "Stock" does not have that R17.5mm radius groove thru it, correct?
A couple pointers:
1) Both files can exist in the same Fusion file, either one as a native and the other as an inserted component, or just to native components in a file.
2) Create a Setup.
3) Select the model that represents which part will be the final resulting model as your "Model":
4) Select the model that represents your "Stock", under your Stock Definition
Seth Madore
