infoEMRZJ
165 Views, 0 Replies
Setup sheets not showing WCS numbers correctly in the Setup section
I have setups with multiple WCS, but those multiple WCS don't show up in the setup sheet.
In the attached screenshot, you can see in the setup section, it only shows one WCS per setup, and just below you can see the first two operations, using WCS 1 and 2 (2 isn't shown in the setup section)
Labels (1)
