ubi.james13
in reply to: seth.madore
Hi @seth.madore
Have had a play with programs so attached is a full working hand edited programme and also the original un-edited. I'm guessing the post needs editing to achieve the same results, can you help? Should add although I have used  Fusion360 for some years I've never before used for Lathe parts only milling having only programmed Mazatrol lathes so this Fanuc Doosan is proving to be a challenge being new to G code lathe programming and a new machine so forgive me if I seem a bit slow !
