03-15-2022
09:49 AM
- Mute
- Permalink
- Report
03-15-2022
09:49 AM
Hi, would like to mill a part similar to the attached part using Y axis rather than using polar co-ordinates but our machine only has 20mm below X so I've programmed two processes with X reversed on one, both work great if run on there own but will not run as single programme . I can see the issue, it is because I'm using the same tool there is no tool Clarence and no G369 Compensation Cancel before it turns it back on
Not sure if this is a post problem or user error
Any help much apricated
Fusion
