03-15-2022
05:43 AM
- Mute
- Permalink
- Report
03-15-2022
05:43 AM
First off, unfortunately the link to your model does not work because the parts were derived in from another source document. Clicking and viewing in Fusion Team right now is not the best for nesting documents sadly. Because of this and the problem you described I am assuming that you have derived parts in through the component sources dialog, correct?
The reference manager is used to update the references to the parts when the external files change in any way and are out of date. This could be because you added a fillet, lets say, or a hole. Have the documents that are in the nesting document been changed at all or moved in the team hub?
Luke Wielgus
Software Development Engineer
Fusion
