engineguy
in reply to: seth.madore
@Lingen.Maschinenbau
@seth.madore
Attached is a sample program that will load to simCNC, however to get it to run you will need to have the correct settings for your version of the Firmware/Software, contact the makers at CS Labs, they are really quick to answer, their suppor is very good.
The correct M codes for the On/Off are M3/M5, I don`t have the full setup manual for the Plasma so I am getting an error when I try to run it, probably down to my settings :disappointed_face:
The code as far I know is correct and loads OK so I have attached it here and it would probably be a good idea for you to send this G Code file to them by email for a proper check.
As I said, it loads OK but just has the one error.
If I get more time I will try to have another go at this :slightly_smiling_face: :slightly_smiling_face:
