- Mute
- Permalink
- Report
I have a very simple part which basically has a 1mm recess with a 1mm radius coming out of it.
Using my tool which has a 0.8mm radius I should be able to face this part and create the face profile but I can't get fusion to do it. I've also tried orientating the tool at 90 deg so the holder is axial to the stock but fusion didn't like that either. I also tried a grooving tool path but it wouldn't work with my selected tool.
Any hints on how to get this profile?
- Mute
- Permalink
- Report
A face toolpath only works in one direction; X.
For anything else, you want to be using 2D Profile > Finishing. Enabling "Allow Axial and Radial Gouging" should send it where it needs to go.
If that still doesn't work, could you share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
- Mute
- Permalink
- Report
Hi Seth,
It's still not plunging in and getting the profile needed. Attached is the file.
Cheers,
James
- Mute
- Permalink
- Report
Like this?
Seth Madore
- Mute
- Permalink
- Report
Yes! That's it. It took me a while to verify because I was trying to replicate in my model. Apart from selecting the face as the back reference, switching off lead in was the key.
Thanks for the help.
Fusion
