mattdlr89
in reply to: bernard5BABD
Without seeing you file. I'd assume you have selected the same tool from your local/cloud library and this has created duplicates of that tool in your document library.
You can check this by going to the tool library and selecting the document in question on the left hand side. If you see the same tool listed multiple times that will be the issue. To fix it just go and reselect the tool in each toolpath to the same instance of it from the document library.
