bernard5BABD
243 Views, 2 Replies
With a personal licence, it's supposed to be possible to have many toolpaths, as long as they all use the same tool. Does NOT Work!
As the title say, if you have a couple of toolpaths, in a setup, Fusion displays a warning saying that you have to create a NC program with the same tool. But in fact, it refuses to generate G-Code as long as there are more than ONE toolpath selected. Does not seem right. Is there some kind of setting I might be missing?
Bernard Grosperrin, Retired, Maker, and Autodesk Certified Instructor
Blog : Le Bear CNC | Forum : Le Bear CNC Forum | Addin : Airfoil Sketch from file
mattdlr89
in reply to: bernard5BABD
Without seeing you file. I'd assume you have selected the same tool from your local/cloud library and this has created duplicates of that tool in your document library.
You can check this by going to the tool library and selecting the document in question on the left hand side. If you see the same tool listed multiple times that will be the issue. To fix it just go and reselect the tool in each toolpath to the same instance of it from the document library.
bernard5BABD
in reply to: mattdlr89
Make sense. Did not think about this. I'll test, but I am sure it will work selecting the tool that way.
