Kzinty
I know this thread is old and dead, but I just wanted to put in my solution for others to reference.
Using an offset boring head is a straight line move in the Z so all you need to do is program a drill cycle with a drill running your desired RPM and feedrate. The depth will be to the bottom of the hole and your tool length offset in the machine will be the tip of the boring bar.
