a.laasW8M6T
in reply to: mchl.shepard
Yea fusion goes a bit funny with Geometry like that.
What you need to do is create a Sketch, then use the Project command with the selection filter set to "Bodies" to project the outline of the part onto the sketch.
You can then use this sketch to drive the 2D contour etc. adjust the cutting heights by using selections etc in the Heights tab.
