02-04-2022
09:22 AM
- Mute
- Permalink
- Report
02-04-2022
09:22 AM
Postprocessor - Simply read of coolant table?
i´m currently looking for a simply way to read the variables from the coolant table:
Today i use the old method to read the first two coolant states from the tool (Flood and Mist) and activate them with M8 and M10:
var mapCoolantTable = new Table(
[9, 8, 10],
{initial:COOLANT_OFF, force:true},
"Invalid coolant mode"
var c = mapCoolantTable.lookup(tool.coolant);
if (c) {
writeBlock(mFormat.format(c));
} else {
warning(localize("Coolant not supported."));
Now i looking for simple method to read the var c from the "new" cooland table method (here from the fanuc pp):
var coolants = [
{id:COOLANT_FLOOD, 8},
{id:COOLANT_MIST, 10},
{id:COOLANT_THROUGH_TOOL, 41},
{id:COOLANT_AIR, 42},
{id:COOLANT_AIR_THROUGH_TOOL, 43},
{id:COOLANT_SUCTION, 44},
{id:COOLANT_FLOOD_MIST, 45},
{id:COOLANT_FLOOD_THROUGH_TOOL, 46},
{id:COOLANT_OFF, 9}
How do i have to adapt the Var c line to read from the var coolant array my numbers as output?
Best case would be something like this to have a easy read function:
var c = mapcoolantsArray.lookup(tool.coolant)
Thanks for help.
Fusion
