- Mute
- Permalink
- Report
Taper Face Part
I can't seem to get this part to CAM up at all. It is struggling with this simple shape.
Any ideas how to make this?
- Mute
- Permalink
- Report
@turbobug64 Can you attach a sample file so I can take a look?
Akash Kamoolkar
Software Development Manager
- Mute
- Permalink
- Report
I have an IPT since I am working on it in Inventor at the moment.
- Mute
- Permalink
- Report
I was going to drill down the center to depth and then use my small boring bar to face it. It wont seem to let me drill without a hole in the center? Or if there is a better way to do it I can do it that way?
- Mute
- Permalink
- Report
Inventor is 3 years behind Fusion in CAM, specially for lathes, so this would very possibly work in Fusion but not in Inventor (I know, I use Inventor mainly as well, but you can't really post an Inventor question here for CAM anymore, the distance between the 2 softwares has grown a lot in the past 3 years). I recommend you post this in the Inventor CAM forum, and hope for the best...
- Mute
- Permalink
- Report
That is cool you guys can CAM it up in fusion if you can get it to work in fusion. I use both of them and always switch back and forth.
- Mute
- Permalink
- Report
Ah so if you go back and forth between the 2, did you try this part in Fusion? Just cause you said you were using Inventor, I thought it meant that you were programming this part in Inventor. If you didn't try in Fusion maybe give it a shot.
- Mute
- Permalink
- Report
No I did not because turning in fusion and inventor is the same. I have yet to find any differences in turning since turning in fusion is so far behind the mill stuff.
- Mute
- Permalink
- Report
I think you are wrong... Inventor CAM has no updates for 3 years, the turning in Fusion is much, much further ahead than Inventor. The only CAM updates that Inventor got in the past 3 years are to keep up with the Inventor version, but no improvements are in it, for 3 years.
Fusion
