will263RT
398 Views, 1 Reply
Mazak post - need to move smoothing (G5 P2) below lengthcompensation (G43) ----- Help!
Im using the generic Mazak post for our VCN 570c.  In order for smoothing to work it (G5 P2) must be called after the G43 line.  I have move the  setSmoothing(smoothing.isAllowed); line to every line I could think of and received either an error or no change in return.  I'm sure this is  a simple fix and it would be so nice not to have to modify each post manually for this.
Thank you for your support!!
Arun.rs
in reply to: will263RT
HI @will263RT
Thanks for raising your concern via Forum.
Open 'Mazak.cps' file in a 'Visual Studio Code' or 'Notepad++' to do the required modifications.
1. Go to line number 1222 , cut the line ' setSmoothing(smoothing.isAllowed);
2. Paste the code at line number 1275 ie, after '
validate(lengthCompensationActive, "Length compensation is not active."); '
3. Go to line number 762, put '//' just before '
validate(!lengthCompensationActive, "Length compensation is active while trying to update smoothing.");
Save the file and test the post carefully.
Regards
Arun.RS
Technical Consultant - Post Processor
