01-21-2022
01:37 PM
- Mute
- Permalink
- Report
01-21-2022
01:37 PM
I have a CNC router setup with a welding head so I can weld sheets of plastic together. I typically use closed loop, trace toolpaths, but I sometimes find it leaves a small gap at the beginning/end where end meets back up with the beginning of the toolpath (imagine a circular trace).
Ideally I'd like to add 1/4" of overlap but can't find a consistent way to do it using the free version of Fusion. Using the circle example, I'll add a 1/4" long arc with the same diameter as the circle, select "Keep Tool Down", and select both paths but Fusion will almost always find an order of operations that doesn't work.
Hopefully that makes some sense, any pointers?
Fusion
