01-15-2022
04:59 PM
- Mute
- Permalink
- Report
01-15-2022
04:59 PM
3D Adaptive is producing small, uneccesary step ups on vertical surfaces
The features above the first full step down in this image are completely vertical, but 3D adaptive is producing these small step ups. What's causing this?
01-15-2022
08:04 PM
- Mute
- Permalink
- Report
01-15-2022
08:04 PM
it does to that sometimes, you can try reducing the tolerance in the passes tab, also sometimes turning off flat area detection can fix it.
seeing as it looks like you have no real "3D" geometry on that part from what I can see(from that orientation anyway), just vertical walls, making the fine stepdown the same as the maximum roughing stepdown will definitely cure it haha.
01-16-2022
05:35 AM
- Mute
- Permalink
- Report
01-16-2022
05:35 AM
Besides from what's been mentioned, try tightening up the tolerance. If they still persist, could you share your file here?
File >Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Fusion
