01-09-2022
01:46 AM
- Mute
- Permalink
- Report
01-09-2022
01:46 AM
Machining angled surface which is turning inwards
I'm trying to make toolpath for part side surface which is 89 degrees from the top surface. To achieve this I'm using dovetail cutter. However I'm not succeeding in making toolpath which would follow the surface. I'm using the 3D parallel toolpath and I succeeded to make this if the angle is 91 deg with endmill. Is it that Fusion 360 just can't do this when you need to go "inside" direction? Attached picture of the scenario and red line shows the surface need to be machined.
Thank you in advance.
Fusion
