vesa.vestman
363 Views, 6 Replies
Machining angled surface which is turning inwards
I'm trying to make toolpath for part side surface which is 89 degrees from the top surface. To achieve this I'm using dovetail cutter. However I'm not succeeding in making toolpath which would follow the surface. I'm using the 3D parallel toolpath and I succeeded to make this if the angle is 91 deg with endmill. Is it that Fusion 360 just can't do this when you need to go "inside" direction? Attached picture of the scenario and red line shows the surface need to be machined.
Thank you in advance.
seth.madore
in reply to: vesa.vestman
You'd actually want to be using a 3D Contour for this. Note; with a sharp corner tool, the surface finish is going to be very rough unless you use an extremely small stepdown
 I've attached a sample file showing the method used
Seth Madore
vesa.vestman
in reply to: seth.madore
Thank you for replying. Is there any way to change the toolpath 90 deg?
If having horizontal toolpath the surface would be like sawtooth..
vesa.vestman
This is as close as I can get it to work, still it won't do the taper.. Hopefully there is some other way than shim the part to 1 deg and finish that surface by endmill. Even any dirty hack/trick to fool it to think it's 91deg instead of 89 or something..
seth.madore
No, parallel does not recognize undercuts, 3d Contour would be your only option, unfortunately
Seth Madore
vesa.vestman
Could this functionality be added to the list of future developments perhaps? :smiling_face_with_smiling_eyes:
seth.madore
We are working on improving our "undercut" machining strategies, so it's possible that a future release would give better tools for this. No timeline on that though, as the work is still in the "idea" phase
Seth Madore
