MattWynn
in reply to: pseebald
I split the big arc in the sketch into 5 smaller arcs using the sketch break function, and changed the lead to 0.2" in and .1" out and seems to work.
You should be able to download from https://a360.co/3lHtl2P
The system is checking the angle at the corner farthest to the -X and down to -Y.  It is using the angle from the start to the end of the segments, not knowing that the segment is a huge arc, and it get the angle wrong.  Smaller arcs get better angles.
Matt Wynn
Senior Manager, Software Development, Fusion Fabrication
