engineguy
in reply to: paramax55
@paramax55
You either do not have permission to set your file to be downloaded or you forgot :slightly_smiling_face: :slightly_smiling_face:
Try the 3D ADaptive for Roughing and then 3D Contour toolpath for a Finish, all I have without seeing the part :slightly_smiling_face: :slightly_smiling_face:
Easiest way to get a Fusion f3d file uploaded to the Forum is to go to :_
File > Export > Select f3d format > Save it to a location on your computer > Then attach to your reply.
If the f3d format does not show as an option then you likely have links in you file to outside sources so you would need to break any links :slightly_smiling_face:
