engineguy
in reply to: engineguy
@nathanhein
Apologies, forgot to mention, if you are trying to use a Contour toolpath the a 0.125 tool will not go all the way into the slot, try using either a smaller tool, a wider slot or maybe use the Trace toolpath, that will go in, see example images below :slightly_smiling_face: :slightly_smiling_face:
Dogbone ContourDogbone Contour
Dogbone TraceDogbone Trace
