seth.madore
in reply to: FlaviuC
Press the ALT key and select a single edge. Release the ALT key and mouse button, rotate the part around and repeat the process for the other edge. Stock contours is optional, you can also achieve part/tool clearance with Tangential Extension
Seth Madore
