- Mute
- Permalink
- Report
I am receiving the "Internal CAM Kernal Error" again... I've followed what other older blog posts have done to fix it but have had no luck. Any Ideas?
- Mute
- Permalink
- Report
The issue is stemming from your Heights tabs. However, I'm curious about your Setup. You've selected the base component, but then you are making a chain around the little posts that are not included in the Setup. What's your goal here?
Seth Madore
- Mute
- Permalink
- Report
I found I needed to select the whole component and I think you need to click the red arrow to switch the offset to the outside. There's still a warring about heights as @seth.madore mentioned.
Mark Hughes
Owner, Hughes Tooling
- Mute
- Permalink
- Report
Ahhhh... Ive been working to fast and botched my setup. Thankyou for the help, works now.
Fusion
