11-04-2021
10:45 AM
- Mute
- Permalink
- Report
11-04-2021
10:45 AM
@Anonymous
Ok, so, I am thinking that you wish to machine outside the edge of your Model, yes??
That is easy enough on your File, you can set the "Additional Offset" to anything you like, I have set it to +6mm as shown in the image below so the whole diameter of the tool is outside the Model, but it isn`t diving down the slots in the Z axis, that is because for that Operation I set the Bottom Height to the top of the model, this stops the toolpath going down any further than the top of the model, if you do want the toolpath to go down the sides of the model then adjust the "Bottom Height" to where you want the toolpath to go to ![]()
This is with the "Bottom Height" set to the Model top with -4mm ![]()
Fusion
