- Mute
- Permalink
- Report
@Anonymous
As I have explained it is the way you are selecting things, if you are selecting a sketch that is already larger than the model then even without any "Additional Offset" it will be over the edge, if you select the edge of the model shape and then add 3mm then of course the center of the tool will be outside the Boundary so why would you set an "Additional Offset" in the first place ??
If you only want the tool to go outside the Boundary by a small amount as in the image below then set your "Additional Offset" to a Minus (-) value, this will move the tool center inwards, just for illustration I used a -3mm value on the 8mm tool and as you can see the tool has only gone over the Boundary of the Model by a small amount, by using the offset (+/-) you do have full control of where your tool will go to ![]()
Fusion
