in reply to: seth.madore
I have highlighted the sketch (pic.1, pic.2) which I am using as a boundary. With “Tool Center on Boundary” turned on the tool center must not exceed the boundary, at least this was the case with my old CAM.
I assume that (“Tool Center on Boundary” algorithm = “Tool Inside Boundary” + boundary with tool radius offset) because a respective offset to this boundary merges it in the problematic areas causing a similar result with “Tool Inside Boundary” turned on (pic.3).
I have mentioned the “Additional Offset” because “Silhouette” + “Additional Offset” + “Tool Center on Boundary” behaves the same way.
P.S. I had the toolpath settings mixed up in the *.f3d project, sorry for that. A fixed project is attached.
