10-28-2021
10:04 AM
- Mute
- Permalink
- Report
10-28-2021
10:04 AM
As you've no doubt seen, there are videos out there, a lot of them good, some of them...less so. I don't have one right off the top of my head to point you towards, but here's a brief rundown of the steps:
1) Create Setup. Define your X and Z orientation
2) Create toolpaths, selecting the correct tools to use and the proper toolpaths. If you are in the Fabrication tab, the only toolpath present to you would be 2D Profile
3) Click the Post Process button, select the Post Processor you are going to use for your machine. This is based on the type of controller you are using. For example, the TorchMate would use the Torchmate post, the Mach3 Plasma would use the Mach3 plasma post, etc etc
Seth Madore
Fusion
