engineguy
@Anonymous
The modification that Matt @mattdlr89 has provided in his uploaded Post Processor works correctly here as well, there are no other modifications required for it to work so don`t go changing anything else.
Are you using the Post Processor from your "Installed Library" ? If so then it is possible that it has been overwritten again by yesterdays update, suggest that you download/copy/paste the PP from @mattdlr89 into your "Personal/Local" Post Processor Library and use it from that location.
The Main "Installed Post Library" is updated/overwritten automatically if you have the automatic updates enabled in your preferences.
