321 Views, 2 Replies
Produce a g-code and tool path for use with a CNC router and Mach3.
Dear All,
Firstly I must apologise for my lack of experience but I am slowly getting to grips with using Fusion 360 and would like to expand my knowledge by generating my first g-code to allow my small CNC router to drill a series of holes of differing diameters. I want to drill/mill the holes using a 4mm carbide 4 fluted slotdrill and increase the diameters with each operation along the centre of a piece of plastic tube which has a wall thickness of 1mm. I have attached the screen shot which shows the hole positioning and diameters.
I would be most grateful if someone could please advise me which steps I need to follow to generate the code etc.
Thank you in advance,
David.
Labels (3)
