- Mute
- Permalink
- Report
Produce a g-code and tool path for use with a CNC router and Mach3.
Dear All,
Firstly I must apologise for my lack of experience but I am slowly getting to grips with using Fusion 360 and would like to expand my knowledge by generating my first g-code to allow my small CNC router to drill a series of holes of differing diameters. I want to drill/mill the holes using a 4mm carbide 4 fluted slotdrill and increase the diameters with each operation along the centre of a piece of plastic tube which has a wall thickness of 1mm. I have attached the screen shot which shows the hole positioning and diameters.
I would be most grateful if someone could please advise me which steps I need to follow to generate the code etc.
Thank you in advance,
David.
- Mute
- Permalink
- Report
No apologies needed, regarding lack of experience, we all started there at some point. So, it sounds like you are REALLY new to the realm of CAM. I can give you a step by step walkthrough, but I suspect it would be of greater benefit to you if you were to do a quick search on YouTube or even read the "Help" guides for Fusion Manufacturing. If you get stuck or confused on anything, we're always here to help sort you out
Seth Madore
- Mute
- Permalink
- Report
Fusion
