- Mute
- Permalink
- Report
When trying to cut a spiral toolpath, the cutting tool picks up and makes another pass from a different direction several times at the beginning of the cut. It is somewhat odd geometry, it is a lens coped to the face of a pipe with a cylindrical boss extruded through the center of the cope. Any suggestions to remove the extra linking moves? Thanks!
- Mute
- Permalink
- Report
Like many things in life, there's more than one way to reach this goal. One quick thing I tried, (and which worked straight away) is turning on "Touch/Avoid" and selecting the inner diameter:
Seth Madore
- Mute
- Permalink
- Report
Thanks Seth! I had tried that, though it looked like it skipped the inner-most path. After trying your solution and looking more closely at the simulation, it does generate correctly.
Fusion
