- Mute
- Permalink
- Report
You would have to use a very small cutter to get in as far as possible using the "Rest Machining" option so it would only be clearing out most of what the 1/8 tool didn`t get to.
The toolpath that would rise up in the corners automatically is the Engrave toolpath, so you could try using a very small angled V cutter of say 5 Degrees and use the edge of the shape for your contour, you will then have a very shallow angle which will of course not be seen if you are filling the shape with Epoxy or similar just means that your shape will be a little larger. If you have a sketch of your shape you can use the "Offset" facility to move the edge of the shape in a fraction to get it to the same size as the original.
However, without you uploading a file the above may not work at all depending on exactly what is needed !!
OK, apologies, you uploaded a file while I was typing, not hard, I type slooowww
Fusion
