boozer69n
322 Views, 4 Replies
Small Corners V Cut
I am really new to F360/CNC so any help please keep it simple for me.
I am doing a small 1/8" deep cut that I plan on filling with epoxy, in the image I am using a 1/8" end mill to attempt to get into the corners and as you can see its not getting there. I do have a V bit, what kind of tool path do you recommend to both clear out the material as well as to get into those corners, it does not need to be the full 1"8" deep, it can slope up in the tighter corners.
In the above image I am currently using 2D Adaptive action with my 1/8" end mill, any guidance would definitely be appreciated if you feel there is a better way. :slightly_smiling_face:
