10-06-2021
02:49 AM
- Mute
- Permalink
- Report
10-06-2021
02:49 AM
When using left handed tools mounted as such in your lathe, you will need to define it as a RH tool. Question; do you have the shims placed on the proper side of the tool block, or should you reverse them and use an actual RH tool? Second question: in the position that the tool is in, will spindle "forward" (M03) turn the material in the correct direction, or will you need to use M04 (reverse)?
Seth Madore
Fusion
