- Mute
- Permalink
- Report
My opinion is that you are not a weirdo... hehe, it would be nice to be able to dictate the last pass to be climb or conventional, but the way it works now is that both ways will ignore that. Both ways means we don't mind if it goes one way or another sort of. But I would like the behavior that you expect tho.
When I encounter that issue, which it does happen from time to time, i just change the start point to the other corner, and that will flip the last cut to climb milling, without the need to split the operation like you described.
If you do that, make sure to set a start point for each of the areas you are cutting, otherwise it will want to start in that general direction for all your zones, which may not result in a climb cut at the end in each area.
Fusion
